March 15, 2007, 00:58 |
Convergence problems... need help urgent!!
Hi folks, I´m dealing with a valve in a duct, 0.05 meter of diameter and long enough to avoid reverse flow and to get a full developed flow. I have to use nitric acid and the mass flow is 15 liters/sec. The problem is that I have to simulate the valve when initiates the opening, so the velocity between the valve and the tube wall is increased very high. Wich models and settings in general are prefered for this kind of problems?
Thanks for your time. H |
March 15, 2007, 01:04 |
Re: Convergence problems... need help urgent!!
Oh! I almost forget... The fluid is supossed to be incompresible. So what density model should I use? constant?
Thanks. |
Gas-liquid vertical separator, problems with convergence | juliom | Main CFD Forum | 0 | October 5, 2011 20:20 |
Convergence Problems | Carlos | FLUENT | 0 | March 12, 2007 02:44 |
NACA0012 Convergence Problems | StudentAndrew | CFX | 6 | November 21, 2005 06:49 |
Convergence problems | Simone | Siemens | 5 | June 29, 2005 10:48 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 19:13 |
