-   -   Granular model with 2d axisymmetric (http://www.cfd-online.com/Forums/fluent/44121-granular-model-2d-axisymmetric.html)
K.Fukumoto March 15, 2007 02:56
Hi, all I am studying spouted bed by granular model with axisymmetric. However if I choose 2d axisymmeric, a sand phase does not be moved.(symmetry condition is OK) Has someone encouted same problem ?
The Model descriptions are Particle size is 1.41mm, density is 2500kg/m3 restitution is 0.9, Gas is Air, inlet velocity is 0.594-1m/s, Drag function & granular viscosity is gidas model,parcking limits is 0.59 turbulent model is mixture k-epsilon, other parameters are default, bed height is 325mm, column diameter is 152mm and orifice diameter is 19mm.
Ethan August 8, 2010 18:42
Hi
Hey, Did u solved ur problem?
mohsen0488 September 15, 2013 11:15
hi
did you solve your problem?
