Air-water interface in a channel flow using VOF method
Old   April 6, 2011, 10:04
Default Air-water interface in a channel flow using VOF method
Jin Lee
Chocosoboro is on a distinguished road
Hi, everyone.
I'm trying to simulate a two-phase channel flow using VOF model.
There are two inlets (one is for water, the other is for air) and one outlet in the present geometry.
In order to know elevation and shape of the air-water interface and velocity fields, I'll change flow rate or air as a control variable.
The domain is filled with water initially, and air layer will be created beneath the top wall using air injection.
Since both fluids have different inlet velocitis, I think "Open channel flow" option is not applicable. And there is a large vertical distance between the two inlets.
Thus, I made two zones (one is for water, the other is for air).
However, phase selection of Cell Zone Conditions is coupled between the two zones.
Models: Multiphase - VOF
Materials: Fluid
water-liquid
air
Solid
aluminum
Phases: air - Primary Phase
water - Secondary Phase
Cell Zone Conditions: air_interior - (air, fluid) <-- I hope
water_interior - (water, fluid) <-- I hope
Boundary conditions: air_inlet - velocity-inlet
water_inlet - velocity-inlet
air_outlet - pressure-outlet
water_outlet - pressure-outlet
Could you tell me how to separate the phase selection or how to modify geometry configuration?
Otherwise, is there anyone who can provide appropriate examples?
Thank you.
Have a nice day :-)
Chocosoboro is offline   Reply With Quote
two-phase flow, vof
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
VOF modelling Open Channel flow Rodi FLUENT 2 August 11, 2007 13:15
open channel flow vof model Yong Siemens 3 June 21, 2005 05:54
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
