Accretion UDF error
Hi, I'm a new FLUENT user and trying to use the accretion UDF. My system is WindowsXP and I'm using the FLUENT Manual UDF example for erosion/accretion. The udf is compiled fine, but when I run it, I got the ACCESS_VIOLATION error. I tryied to find out at which point the code is crashed and it seems like it occures in function DEFINE_DPM_EROSION at point of: if(!check_for_UDM()), but i'm not shure...Does anybody have such a problem? Thanks a lot for help! Here is the code i'm using (from FLUENT Manual):
#include "udf.h" #define MIN_IMPACT_VELO -1000. /* Minimum particle velocity normal to wall (m/s) to allow Accretion.*/ Domain *domain; /* Get the domain pointer and assign it later to domain*/ enum /* Enumeration of used User-Defined Memory Locations. */ { NUM_OF_HITS, /* Number of particle hits into wall face considered.*/ AVG_DIAMETER, /* Average diameter of particles that hit the wall. */ AVG_RADI_VELO, /* Average radial velocity of "" "" ------------ */ NUM_OF_USED_UDM }; int UDM_checked = 0; /* Availability of UDMLs checked? */ void reset_UDM_s(void); /* Function to follow below. */ int check_for_UDM(void) /* Check for UDMLs' availability... */ { Thread *t; if (UDM_checked) return UDM_checked; /* if (!rp_axi)*/ /* Internal_Error("UDF-Error: only valid for 2d-axisymmetric cases!\n");*/ thread_loop_c(t,domain) /* We require all cell threads to */ { /* provide space in memory for UDML */ if (FLUID_THREAD_P(t)) if (NULLP(THREAD_STORAGE(t,SV_UDM_I))) return 0; } UDM_checked = 1; /* To make the following work properly... */ reset_UDM_s(); /* This line will be executed only once, */ return UDM_checked; /* because check_for_UDM checks for */ } /* UDM_checked first. */ void reset_UDM_s(void) { Thread *t; cell_t c; face_t f; int i; if (!check_for_UDM()) /* Don't do it, if memory is not available. */ return; Message("Resetting User Defined Memory...\n"); thread_loop_f(t, domain) { if (NNULLP(THREAD_STORAGE(t,SV_UDM_I))) { begin_f_loop(f,t) { for (i = 0; i < NUM_OF_USED_UDM; i++) F_UDMI(f,t,i) = 0.; } end_f_loop(f, t) } else { Message("Skipping FACE thread no. %d..\n", THREAD_ID(t)); } } thread_loop_c(t,domain) { if (NNULLP(THREAD_STORAGE(t,SV_UDM_I))) { begin_c_loop(c,t) { for (i = 0; i < NUM_OF_USED_UDM; i++) C_UDMI(c,t,i) = 0.; } end_c_loop(c,t) } else { Message(" Skipping CELL thread no. %d..\n", THREAD_ID(t)); } } /* Skipping Cell Threads can happen if the user */ /* uses reset_UDM prior to initializing. */ Message(" --- Done.\n"); } DEFINE_DPM_SCALAR_UPDATE(dpm_scalup,c,t,if_init,p) { if (if_init) P_USER_REAL(p, 0) = 0; /* Simple initialization. Used later for stopping trajectory calculation */ } DEFINE_DPM_EROSION(dpm_accr, p, t, f, normal, alpha, Vmag, Mdot) { real A[ND_ND], area; int num_in_data; Thread *t0; cell_t c0; real radi_pos[2], radius, imp_vel[2], vel_ortho; /* The following is ONLY valid for 2d-axisymmetric calculations!!! */ /* Additional effort is necessary because DPM tracking is done in */ /* THREE dimensions for TWO-dimensional axisymmetric calculations. */ radi_pos[0] = p->state.pos[1]; /* Radial location vector. */ radi_pos[1] = p->state.pos[2]; /* (Y and Z in 0 and 1...) */ radius = NV_MAG(radi_pos); NV_VS(radi_pos, =, radi_pos, /, radius); /* Normalized radius direction vector.*/ imp_vel[0] = P_VEL(p)[0]; /* Axial particle velocity component. */ imp_vel[1] = NVD_DOT(radi_pos, P_VEL(p)[1], P_VEL(p)[2], 0.); /* Dot product of normalized radius vector and y & z components */ /* of particle velocity vector gives _radial_ particle velocity */ /* component */ vel_ortho = NV_DOT(imp_vel, normal); /*velocity orthogonal to wall */ if (vel_ortho < MIN_IMPACT_VELO) /* See above, MIN_IMPACT_VELO */ return; if (!UDM_checked) /* We will need some UDMs, */ if (!check_for_UDM()) /* so check for their availability.. */ return; /* (Using int variable for speed, could */ /* even just call check_for UDFM().) */ c0 = F_C0(f,t); t0 = THREAD_T0(t); num_in_data = F_UDMI(f,t,NUM_OF_HITS); /* Average diameter of particles that hit the particular wall face:*/ F_UDMI(f,t,AVG_DIAMETER) = (P_DIAM(p) + num_in_data * F_UDMI(f,t,AVG_DIAMETER))/ (num_in_data + 1); C_UDMI(c0,t0,AVG_DIAMETER) = F_UDMI(f,t,AVG_DIAMETER); /* Average velocity normal to wall of particles hitting the wall:*/ F_UDMI(f,t,AVG_RADI_VELO) = (vel_ortho + num_in_data * F_UDMI(f,t,AVG_RADI_VELO)/ (num_in_data + 1); C_UDMI(c0,t0,AVG_RADI_VELO) = F_UDMI(f,t,AVG_RADI_VELO); F_UDMI(f, t, NUM_OF_HITS) = num_in_data + 1; C_UDMI(c0,t0,NUM_OF_HITS) = num_in_data + 1; F_AREA(A,f,t); area = NV_MAG(A); F_STORAGE_R(f,t,SV_DPMS_ACCRETION) += Mdot / area; /* copied from source. */ P_USER_REAL(p,0) = 1.; /* "Evaporate" */ } DEFINE_DPM_LAW(stop_dpm_law,p,if_cpld) { if (0. < P_USER_REAL(p,0)) P_MASS(p) = 0.; /* "Evaporate" */ } DEFINE_ON_DEMAND(reset_UDM) { /* assign domain pointer with global domain */ domain = Get_Domain(1); reset_UDM_s(); } |
