combustion
Like Tree1Likes
  • 1 Post By Zenith
Old   March 18, 2007, 10:08
Default combustion
selva
can anyone tell me how to give equivalence ratio value in fluent. thanks in advance
Old   March 21, 2007, 04:17
Default Re: combustion
Zenith
HI
Equivalence ratio value input depends on the type of combustion, one is trying to model. It offers following types of combustion models
Premixed combustion
Non premixed
Partially premixed
What type of model You are using.
zenith mark
Benaissa Sabrina likes this.
Old   March 21, 2007, 10:14
selva
hi, i am modeling premixed combustion with an equivalence ratio of 4.4. i know the air and fuel velocity and i have given the value at the boundary condition along with the species mass fraction. then where we have to specify the equivalence value? or equivalence ratio is used to find air and fuel velocity? plz reply thanks
Old   March 22, 2007, 02:41
zenith
HI
For premixed combustion, species transport equations are not solved. Fluent solves the equation for mean progress variable'c'. Hence species in there elemental compostion remain conserved for premixed combustion. So we are left with the conservation of energy, how Fluent does it.
Dear if you are using premixed combustion model then there are two possiblities
1) adiabetic
In adiabetic premixed combustion, energy equation is not solved. Temperature of mixture is calculated from the temperature of inlet mixture and adiabetic flame temperature. Fluent assumes or fits a linear approximation bewteen these two temperature limits.
2) nonadiabetic
in non adiabetic premixed combustion, energy equation is solved, so two informations are needed, first heat of combustion and the other is mass fraction of unburnt fuel
It is the second parameter " mass fraction of unburnt fuel" in inlet stream which is calculated from equivalence ratio.
Mass fraction apperas in the material properties of mixture. Defining this parameter means that you are defining the equivalence ratio. You will not see this parameter it modeling adiabetic system
Hope this answers your question
Zenith mark
Old   March 22, 2007, 23:00
selva
thanks ya, i am using adiabatic condition. from ur answer i feel that i am in correct path. thanks a lot
Old   June 12, 2017, 08:08
Default help
Manina Sabi
Benaissa Sabrina is on a distinguished road
could you tell me please how to give equivalence ratio value in fluent and my type is non-premixed. thanks in advance
Benaissa Sabrina is offline   Reply With Quote
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
Multiresolution + Turbulence + Combustion Raul Main CFD Forum 0 March 18, 2005 07:53
