3d mesh
Old   March 19, 2007, 09:44
Default 3d mesh
ANTHONY
Hello , I have a bric anda sphere inside it , i wana mesh the flow domain , so i have to subtract the volumes , then do the mesh ; unfortunately , it is not workin , can u help me in ths? regards
Old   March 19, 2007, 10:30
Default Re: 3d mesh
A A S
What type of mesh are you trying to use? Hexahedral? Tet? Structured? Will you use map, submap, cooper? You may need to tweak your geometry a little bit in order to get Gambit to mesh your flow domain the way you want.
Regards
Old   March 19, 2007, 10:36
Default Re: 3d mesh
Palani Velladurai
hi ! whats not working exactly.....?
subtracting volmes or meshing ?????
adn what meshing tool u r using ???
Old   March 19, 2007, 11:15
Default Re: 3d mesh
ANTHONY
thanks for your reply,
When i a substractin the volume , and tryin to mesh with a tetra/hyb , type Tgrid , i got the mesh for the brick only , with no space inside it (so there is no hollow inside the brick that represent the subtracted sphere ); i will aaprecitae ur reply as soon as possible!
thank you very much
Old   March 19, 2007, 19:06
Default Re: 3d mesh
Vivek Vasudevan
Since you are dealing with regular geometries, you should be able to create in Gambit a 'real' brick and sphere and subtract one from the other. You can now mesh this composite subtracted volume without any hassles.
Regards, Vivek
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
