Home > Forums > FLUENT
parallel error
Old   March 21, 2007, 09:27
Default parallel error
kucukco
hi all i have a problem on parallel processing in fluent v.6.2.16
.................................................. ....... iter continuity x-velocity y-velocity z-velocityMPI Error, rank:1, function:MPI_ALLOC_MEM, No additional memory could be all ocated MPI Error, rank:0, function:MPI_ALLOC_MEM, No additional memory could be allocated MPI Error, rank:2, function:MPI_ALLOC_MEM, No additional memory could be allocated node 999999 retrying on zero socket read.....
999999 (mpsystem.c@1228): mpt_read: failed: errno = 11
999999: mpt_read: error: read failed trying to read 8 bytes: Resource temporarily unavailable
EOF on command stream. The fluent process could not be started.
time/iter
Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed.
> Halting due to end of file on input. ..............................................
my msh has 2million elements containing sliding mesh. and i have 2 processors each 600mhz mips / 32gb. no problem in single processor but in parallel. anyone knows if the reason sliding mesh? journal file? partitioning method? or hardware?
i need help immediately...
Thread Tools
Trackbacks are On
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
user defined function cfduser CFX 0 April 29, 2006 10:58
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
