reversed flow
Old   February 20, 2007, 23:30
Default reversed flow
Sastry
hai friends,i am having only one proublem in my solution, i am getting reversed flow during the iterations, due to this my inlet pressuere is increasing that the value given,
how can reduce the reversed flow during the iterations inlet total pre= oulet static pre --> no recersed flow inlet total pre< outlet statis pre --> reversed flow coming but my condition is ps2/p01>3.5
please help any thing what u know in this regard
Old   March 1, 2007, 06:40
Default Re: reversed flow
Pratik Mehta
set turbulence intensity at the pressure outlet very low , this should solve it
Old   March 7, 2007, 08:20
Sangeeta
I wanted to knw whether i should continue iterations even if it says reverse flows. will this iteration converge even if at some places there are reversed flows.
or i should give change the boundary conditions as soon as i get reversed flows while iterating.
Plz Help. Thanks in advance
Old   March 9, 2007, 04:21
ravindra
hi solution converges if the reversed flow comes at some places in the domain. when i simulated my problem, if reversed flow occurs at some places, my problem solution converged for residuals of e-6 and e-8. but you should have some validation for your solution, to decide whether converged solution is correct or not.
compare with ( some correlation) it , if the results are with in 5% error, u can take the solution.
hope this helps.
Old   March 22, 2007, 00:18
Sastry
ok some times reversed flow during the iterarions, will give the bad results,for some proublems like compressor starting the reversed flow during iteration is an indication of surging, try to change the bounadary condyions to avoid reversed flow
ok?
Old   March 22, 2007, 08:05
Sangeeta
Thanks
reversed flow free FLUENT 4 February 27, 2014 01:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Combatting reversed flow tucker FLUENT 1 July 27, 2005 01:32
