March 23, 2007, 15:00 |
Species Transport Convergence
I am trying to eventually use Fluent's SOFC module and am having problems in the setup, namely the species transport model. I have a tubular SOFC geometry which has air flow through the tube at 873K and fuel, 89% H2 and 11% H2O, flowing on the outside at 1273K. The tube is made of a porous wall with a porosity of .3. When I run the fluid flow and heat transfer I have no problem but when I turn on the species transport model it causes the simulation to diverge. I get errors about temperature limits and reversed flow and then it diverges.
If I change the temperature of the flow it will diverge faster or slower depending on the numbers used but it does not make a big difference, I looked at temperature combinations between 800K and 1200K. Can anyone offer me any suggestions about why this would happen? Or specific areas to look at? Thanks Emily |
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 07:42 |
Fixed Bed Gasifier, Species Transport Problem | therandomestname | FLUENT | 12 | January 4, 2019 07:08 |
convergence problems by species transport | Felipeb | FLUENT | 10 | July 15, 2018 07:45 |
Please help!! Patch and Species transport | Julie | FLUENT | 5 | August 3, 2016 03:10 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
