3Dblade mesh
Hi, I'm trying to mesh a flow passage over 3D blade domain. The blade is twisted and its cross-section changes with the heigth.The flow domain is small, inlet is placed one chord length upstream and outlet two chord lengths downstream the blade, the other boundaries are offsets of the blade surface and the flow has a 90deg turn. I created a mesh on of the blade surface and attached a b.l. mesh. So far I was not able to mesh the entire volume using the different schemes. Any suggestion? Should I divide the volume in blocks?
Thanks |
Re: 3Dblade mesh
Yes.
Which software do you use, Gambit? |
Re: 3Dblade mesh
yes, I'm using Gambit. Anyway, dividing the volume in blocks I was able to mesh it. Thank you.
