Shadow wall
Old   August 18, 2010, 07:31
Default Shadow wall
Khurram
deep_seak is on a distinguished road
Hi guys,
I am trying to re simulate the nucleat boiling tutorial using the geometry i created in gambit but which is identical to the one used in the tutorial. Problem is that when i used "heat flux" as the wall and shadow wall boundary condition and using their respective udf macros, no heat transfer happens between the solid and fluid region. But when i used the coupled boundary condition for the wall and its shadow using either one of the udf macros for fluid or solid region, heat transfer begins between solid and fluid zones. Can anyone suggest why is it happening ?
deep_seak is offline   Reply With Quote
conjugate, heat transfer, shadow wall
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Shadow wall Mohsin FLUENT 0 August 15, 2010 20:15
wall shadow amar FLUENT 1 February 5, 2010 06:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
