-   -   Problem in Tutorial problem of fluent (http://www.cfd-online.com/Forums/fluent/44256-problem-tutorial-problem-fluent.html)
Phanindra March 27, 2007 03:45
Dear friends,I'm having a problem in the tutorial practice given in the Fluent. The problem is in the Non-Premixed combustion model Tutorial problem he instructed to develop a pre-PDF file using a sequence of steps.
The first step is setup-model. I dont know where it is available and also i want to know how to setup pre-PDF file for non-premixed combustion model. Kindly help me in this regard. Thanks in advance, Phanindra.
Seyed Farid Hosseinizadeh March 28, 2007 16:50
Re: Problem in Tutorial problem of fluent
Hey: I guess I have some examples of fluent. Just please to check it. Please send me an email to mine: Hossesf@engr.uconn.edu. I don't know that I have this example or not. But I had, I will let you know. Thanks/Farid
Rizwan March 28, 2007 22:13
u need to copy it from the cd. wen u install, the tutorial mesh files are not directly copied to hard disk, but u need to copy them separately. As far as I remember, one of my collegue working on combusition faced the same problem and he had to copy 2 files separtely 1 mesh file and the other was pre-pdf file i think so. Please verify in this dimension tooo.
Best Regards Rizwan
ejaza the chuitia March 28, 2007 23:57
abay ejaza ab tu par le . kion short cut dondta pirta hain berwe ke ulad
ejaza the chuitia March 29, 2007 00:16
masoud April 17, 2007 09:57
I work on my M.SC thesis about wet and dry cyclones . I have this problems about fluent software: 1-in injection menu,the choices of "droplet" and "combusting" is inactive and only "inert" is active. I need to use "droplet". 2-for spray towers or wet cyclone what type of multiphase flow is suitable? thanks a lot.
