modifying turbulent flow equations
Old   March 27, 2007, 13:18
Default modifying turbulent flow equations
Fadi
is it possible to modify the modeling equations in fluent. I'm trying to do research on improving certain models, for example i'm trying to add terms to the k-epsilon model to see if i can improve it. i'm interested in running the modified model in fluent. is that possible?
Thank you.
Old   March 27, 2007, 14:26
Default Re: modifying turbulent flow equations
KPodila
Mr. Fadi, It is possible to modify the equations. I am not sure which model especially you want to modify but yes you can add source terms provided Fluent allows an UDF hook to it. I am not sure if you are working with mutliphase flows but my experience with modifications lie in mutliphase turbulence especially with dispersed k-e approach in Eulerian _ Eulerian frame work. We can discuss our views and Ideas if you are interested and working along the same lines. Good Luck! KP
Old   March 30, 2007, 07:23
Fadi
Hello, I was checking the UDFs and the DEFINE macros. it seems i can only change the viscosity equation. what i want is to replace the two k-e equations that form the k-e model with two new equations that I made and run the solver. what i want to do is compare the k-e model vs. the model i want to write.
LBM Vs navier stokes equations in turbulent fluid flow modeling. sharad_shevate Main CFD Forum 0 August 3, 2009 02:25
Turbulent flow + VOF CK FLOW-3D 3 January 13, 2009 08:30
simulate a turbulent flow model lenson Siemens 3 December 27, 2005 02:27
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
