April 2, 2007, 15:30 |
Gambit mesh output
When I generate mesh with Gambit, if I use Fluent 4 as the solver, there is no problem to export the mesh, however, if the solver Fluent 5/6 is used, there always error mesg indicating 'boundary entity XXX does not contain any valid entity and is not written'.
I just created a 2D rectangle directly, and meshed it, then defined the boundary condition ( wall for upper and lower edges, and velocity_inlet for left and pressure_outlet for right edge) Could any one tell me what is wrong ? Thanks |
April 2, 2007, 17:31 |
Re: Gambit mesh output
I think for Fl5/6 in the export window you have to specify "Export 2D".
April 2, 2007, 22:51 |
Thanks for your reply, Bashu.
Could you tell me where is the option 'Export 2D' ? I can not find it in the export list. |
April 3, 2007, 09:57 |
when you export the mesh, you will see the option "export 2d" just choose it
April 3, 2007, 13:35 |
Thank!
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
