Couette-Taylor Theory modeling
Old   April 9, 2007, 10:38
Default Couette-Taylor Theory modeling
Fabio
hello anyone,
I'm trying to simulate a small oil gap, between a rotor (rotation wall) and a stator (static wall) to estimate the power losses due to viscous shear-stress. I know it's all about Couette-Taylor Theory and I was wondering if someone else could give some advises. I did a 20 degree model in Gambit and on the rotor wall I set as a symmetric condition. The stator wall as a wall and on the gap wall I set as periodic condition. Is it correct? Couette-Taylor Theory gives me a Turbulent and an Instable Flow, so a K-E turbulent model have to be applied. How about the B.C in Fluent? There is anyway to simulate conduction in both sides using the heat generated by this viscous dissipation at the same time? Thanks.
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 07:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
