error when animating
Old   April 18, 2007, 06:56
Default error when animating
Ralf Schmidt
Hi!
I have a graphic error, when I animate a instationary simulation:
With some sequences, the graphic display is not right. e.g. I display the temperature contours. When setting the properties everything is ok. But when i leave the define animate menue, the view section changes, the contours are deleted and the scale is destroyed.
following message appears:
Error message from graphics function Show_Camera_Target: Can't "Show" - attribute is not currently set in '/driver/x11/:0.0+w0/inner/main'
No error handler available
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
WHAT IS THE PROBLEM???
When i start iterating, following message appears:
(ani-monitor-update 4 #t #t) Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
something similar happend also when i used x-y-plot as animation sequence...
Any Idea????
Ralf
Old   April 18, 2007, 09:11
Default Re: error when animating
Markus
its a bug. Fluent uses a poor code. I know that problem. You can do nothing. M.
Animating flapping motion doctsh FLUENT 2 August 22, 2011 11:05
Animating a solution - help badly needed Dave FLUENT 11 August 20, 2007 05:00
Animating VIV around 2D cylinder Dash Swift FLUENT 0 August 19, 2006 20:19
Animating Comet results Derek Coon Siemens 6 December 9, 2004 14:37
animating unsteady flows phil FLUENT 2 December 2, 2002 05:07
