Home > Forums > FLUENT
fixing pressure in some cells
Old   April 22, 2007, 08:02
Default fixing pressure in some cells
asghari
Hi
How can we set gauge pressure in some cells to a desired value?
Is it neccessary to write a UDF for this purpose?
Thanks
Old   April 26, 2007, 12:59
Default Re: fixing pressure in some cells
Tim Magurie
Usually you would just set the pressure at a boundary condition. Can you define the geometry you are modeling so as to help define where you would need this pressure specified.
Old   April 27, 2007, 03:36
Asghari
Ok, my geometry is a 2D Mixing Elbow and there are two inlet boundary in my geometry with difference inlet gauge pressures .I did'nt find in Manual how to adjust/set difference inlet gauge pressures. For example suppose :
Gauge pressure at inlet boundary 1 is:
1barg
and
4barg
How can I adjust this problem for instance using the Velocity-inlet boundary type.Also velocities in inlet are exactly specified and equal with 1m/s.
Thanks a lot .
Old   April 27, 2007, 08:35
Tim Magurie
The way to do this is to not set your boundaries as velocity inlets, put as pressure inlets. Then you can specify the pressure at those two points. Just make sure your outlet boundary condition is also setup.
Old   April 27, 2007, 12:05
Asghari
Thank you.
Yes, But there is a problem in my settings. I must set either pressure and velocity synchronously .
I read Manual for setting of pressure inlet boundary condition type . I felt it is well to bring to the notice of you , the section that describes this boundary condition as follows :
"Pressure inlet boundary conditions are used to define the fluid pressure at flow inlets,along with all other scalar properties of the flow. They are suitable for both incompressible and compressible flow calculations. Pressure inlet boundary conditions can be used when the inlet pressure is known but the flow rate and/or velocity is not known.This situation may arise in many practical situations, including buoyancy-driven flows.Pressure inlet boundary conditions can also be used to define a "free" boundary in an external or unconfined flow."
as you consider, for this boundary condition type, we can only set pressure at inlet and velocity evaluates in solution processes and it is impossible to set pressure & velocity syncronously, but inlet velocity is perfectly set to 1m/s in the my case and also I brought for you inlet pressure values in previous message. Therefore I can't use pressure inlet for this case. Can I use UDF for fixing of gauge pressure in inlet ?
Have you a better idea for this problem?
Thanks in advance for your kind attention.
Old   May 13, 2007, 12:07
imaduddin
as far as i know, pressure inlet BC could define velocity inlet sychronously with pressure as a total pressure quantity. If we assuming the static pressure inlet equal to zero, then the total pressure will be equal with velocity pressure ==> (0.5*rho*v^2). I've been trying this and it's work, as long as we keep the pressure difference between pressure inlet and pressure outlet.
Regards
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Fixing the pressure prakash FLUENT 0 April 23, 2006 22:03
Pressure interpolation between cells Steve Moore FLUENT 9 September 7, 2005 00:44
physical boundary error!! kris CD-adapco 2 August 3, 2005 00:32
