3Dblade
Old   April 25, 2007, 15:11
Default 3Dblade
dan
hi, I'm simulating flow and heat transfer through a gas turbine blade passage. I'm using a dual core with 4GB RAM. With the 3D (1.5E06 nodes) mesh I'm using now, and using a Density-Based solver, I can run the simuation only partitioning the mesh. one partition for each cpu. The problem is that x and y velocity residuals at some point drop several orders of magnitude, then increase again or oscillate and I have the following error:
Error: > (greater-than): invalid argument [2]: wrong type [not a number]
The previous mesh I used (1.3E06 nodes), worked well with the Pressure-Based Solver without partitioning the mesh. Any suggestions? Thanks
Periodic Conditions - 3Dblade nick FLUENT 0 May 22, 2007 11:57
3Dblade dan FLUENT 5 April 13, 2007 10:31
3Dblade mesh dan FLUENT 2 March 30, 2007 17:20
