(Ageometric/ Aeffective)
Old   May 4, 2007, 09:04
Default (Ageometric/ Aeffective)
Venugopal Bachu
Hello! all,
I do CFD on manifolds, generally steady state with mass flow or pressure conditions. My typical targets are pressure drop or minimum mass flow rates.
One of the customers requested the target to be
(Ageometric/ Aeffective)^2 < 0.60
What does this mean?
Thanks Venu
Old   May 4, 2007, 09:23
Default Re: (Ageometric/ Aeffective)
Phil
(geometric(physical) area / effective(aerodynamic) area)*SQUARED*
<less than:
0.6
Old   May 4, 2007, 09:24
Phil
< 0.60 = less than 0.6
Old   May 4, 2007, 09:30
Venugopal Bachu
Thanks! Phil,
I am kind of novice to this method. Basically can do a steady state run with all ports flowing. Then I am assuming that geometric area is the total surface area of the flow volume (manifold). Is there a way to calculate aerodynamic area in say Fluent?
Thanks a lot Venu
Old   May 4, 2007, 09:42
Phil
I'll tell you what I tell everyone, do the relevant tutorials and look at the user guide! I get the impression you work so you could even get paid to do it. It wouldn't take long.
For all the basic notation and maths,etc the web is the best thing to use, or the fluent documentation. Wikipedia is really good!!!!!!!!!!!!!!!!
Old   May 4, 2007, 09:45
Venugopal Bachu
Thanks! Phil, for your valuable lessons and suggestions. Appreciate it.
Old   May 4, 2007, 12:07
bashu
Venu,
For all I know the effective flow area can not be larger than the geometric area. That's what the crietria suggests, right?
For example at a 90 degree bend the flow after the bend doesn't occupy the whole pipe cross section. So if you define a plane after the bend and look at velcoity profile it shows very low velocity areas wich can be clipped and its area can be reported in Fluent.
Hope this helps.
(Ageometric/ Aeffective) target Venugopal Bachu Main CFD Forum 0 May 4, 2007 09:04
