May 2, 2007, 15:06 |
Solver
Hi, can I run a case using Pressure Based Solver, Cell Based Gradient Option and 1st order schemes for few iterations and then switch to the Density Based Solver, Node Based Gradient Option and 2nd order schemes ? I'm simulating high speed compressible flow, but if I use directly the Density/Node Option either the solution diverge or I have errors.
Thanks |
May 2, 2007, 16:44 |
Re: Solver
Why can't you just ask Fluent for afew iterations, change the options in the solution panel then continue?
Display Modes | |
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 10:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 10:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 13:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
