Help with Fuse function
Old   May 4, 2007, 18:03
Default Help with Fuse function
derick
Guys:
I read in a case file that I merged using tmerge into fluent. I was able to fuse the interface boundary condition on a single processor. When i try doing the same thing on 2 processors, it does not highlight the fuse function in fluent at all. Anybody have any idea why this is or any way by which i can run multiple case files in parallel.
Thanks in advance,
Derick
Old   May 11, 2007, 17:38
Default Re: Help with Fuse function
mystic_cfd
Hi Derick,
If I recall correctly, you cannot do any grid manipulation in parallel (including merge, fuse, separate). That is why the options are grayed out. You will have to assemble the grids in the serial solver, save the case and then open it in the parallel one.
But there might be other options of which I am not aware.
regards
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
