combustion
Old   April 2, 2007, 05:40
Default combustion
zenith
i am using pdf model with equilibrium, non adiabetic options. according to theoritical calculation
1) Adiabetic flame temperature of kerosene should be 2300 kelvin, but i am having max temp. upto 2550 kelvin in my solution domain. What could be the reason
2) Heat added by the fuel comes far less than the theoritical value. so the outlet temperature is coming on the lower side for the oxidation of same amount of fuel. I assume all the paritcale evaporate should produce heat.
i have activated 5 species. including co and co2.
Including more species in calculation can make effect on heat released by the fuel and max temp?
thanxs in advance
zenith mark
Old   April 8, 2007, 21:07
Default Re: combustion
Phil
these cfd models generally aren't that accurate. you need a detailed reaction mechanism. There could though be a million reasons for the high temp. Look for papers with similar calculations.
you should try species transport with volumetric reactions perhaps eddy dissipation and see what the temp is.
also try a lower air temp and check your other calcs. This is the way it is, bang your head off a brick wall for hours,days,weeks,months one of those then at a random time it clicks into place.
good luck.
Old   April 10, 2007, 13:27
zenith
Thanks Dear
i am using air entering at temperature 700K. If i lower the entering temperature of air, then i think adiabetic temperature will not be exceed.
Can u let me know about any source from where i can get the mechanism reactions for kerosene.
thanks in advance
zenith
Old   April 10, 2007, 14:22
Phil
not sure - would need to speak to a University or search online.
Old   April 10, 2007, 14:59
zenith
Hi
Phil do you have any idea, what does this message means
" particle concurrency 5% "
while modelling injection in dpm model
zenith
Old   April 12, 2007, 15:52
jeffery
There is an assumptiom in the procedure of calculating adiabetic temperature that both fuel and air are room temperature is applied . So, it is possible the combustion temperature is higher than adabetic temperature if inlet air temperature is very high. BTW, Cp value for air and combustion products is a function of temperature. You should define it yourself. Else you will get higher temperature.
Old   May 1, 2007, 09:13
mohamed saleh
i'm pleased to know you,please help me to find the following: all files is required: data base,mesh,case,data and analysis file
Old   May 1, 2007, 09:17
mohamed saleh
Old   May 1, 2007, 10:26
Phil
I am unsure what you mean by 'find' the files.
database = .dbs mesh = .msh case = .cas data = .dat analysis = ?(unsure)
these are the file extensions that Fluent uses. You need to create these files yourself using Gambit then Fluent. This is what CFD is!
You can find tutorial files with all these extensions.
Old   May 16, 2007, 09:22
mohsen
about swirl burner
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
Multiresolution + Turbulence + Combustion Raul Main CFD Forum 0 March 18, 2005 07:53
