Fuseing in 6.3
Old   May 8, 2007, 21:24
Default Fuseing in 6.3
Cory
I ran into a unqiue problem today. I am running a windows CCS HPC, and when I try to use the Fuse function in 6.3 it looks like it attempts to fuse them together but it never combines the interfaces and make an interior. I can take the same cas to an older version 6.2 and run it on a Basic Windows XP machine and it will fuse fine. Has anyone seen this, I used tmerge to combine the file before reading in and fusing. I am somewhat new to my job, I used Fluent on Unix and it worked fine, but the company does not use unix it has a CCS HPC set up. Any help would be appreciated.
Thanks Cory
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Backwards compatibility of Fluent 6.3 with 6.2 Brian FLUENT 1 April 4, 2007 21:52
Impressions of V 6.3 Allan Walsh FLUENT 0 January 4, 2007 11:20
