May 14, 2007, 16:31 |
Multiphase flow!
Hey, I'm doing a study on cavitation around a propeller using fluent and I'm trying to use a multiphase flow (water liquid and water vapor). I checked fluent's tutorials about cavitation and they said that I should have two inlets (Inlet 1 as liquid and Inlet 2 as vapor) but in Gambit when I defined Inlet 1 and Inlet 2 on the same inlet face boundary, fluent wasn't able to see both inlets and it shows only 1 inlet... what should I do to define a multiphase flow??
Please help! |
May 15, 2007, 04:16 |
Re: Multiphase flow!
Hi!
I don't think you have to define liquid and vapor inlet for cavitation simulation... Cavitation in Fluent can be a problem but in latest versions it work fine if you know a few tricks. I did most of simulations in Fluent 6.1 and unsteady. If you want some papers where I described what I did you can send me an e-mail. There was also a article about my work in Fluent-News (fall 2004 issue - I'm not sure). By MATEUS |
May 16, 2012, 15:57 |
help
#3 | |
david
hi
i'm working on the marine propeller together with sheet cavitation and of coure hase some problem to capture it correctly, please send me your investigates for seting up FLUENT and your advises(davidmurphy26@ymail.com) sincerly your david Quote:
Multiphase flow information | amir | FLUENT | 2 | May 25, 2007 06:01 |
Realizable k-epsilon eqns for multiphase flow | Rana | FLUENT | 0 | December 8, 2006 13:46 |
Multiphase flow modeling | Paul | CFX | 2 | August 11, 2003 09:41 |
Multiphase Flow | mbga8ejf | CFX | 0 | July 10, 2003 10:26 |
multiphase flow | Shane Gillis | FLUENT | 10 | August 28, 2000 19:12 |
