-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Convergence problem (https://www.cfd-online.com/Forums/fluent/44731-convergence-problem.html)
akr May 17, 2007 03:17
Convergence problem
Hi, I want to solve gas flow in chamber. The geometry of chamber is 0.3 in width, 0.3 in height and 0.05 m in depth. The inlet is circle whose diameter is 0.013 m and set on the side face (0.3 by 0.05 m). The outlet is also circle whose diameter is 0.013 m and set on top face (0.3 by 0.05 m). The inlet is velocity inlet boundary and the velocity is 2.5 m/s. The outlet is pressure outlet boundary. And I am solving with laminar model. When this calculation starts, the residual decrease to 10-2. But after that, the residual keeps flat and never decrese. Is this converge? Thanks, akr
Adriano May 17, 2007 04:21
Re: Convergence problem
Hi, Try to check the under relaxation factors (reducing them), try to change discretization scheme and pressure-velocity coupling scheme (i.e.: Simple). After, If You don't reach convergence, check your mesh!
Hope it's helpful,
best regards Adriano
Madhukar May 17, 2007 10:27
Hi
U had the same question, which i had 2 days back.... there was a small but valuable discussion on this topic yesturday in the forum...you can find it under
http://www.cfd-online.com/Forum/fluent.cgi?read=48852
regards
akr May 17, 2007 20:59
Thank you for your responses. I will also try to use turbulence model instead of laminar model. But now what I don't understand is which model is best for my case. In my case, reynolds number is about 3000 at inlet. Do you know which one is best??
Regards, akr
Madhukar May 18, 2007 07:21
Give a try with standard K-Eps Model
Regards
Madhukar
akr May 19, 2007 02:24
Hi Madhukar,
Is it O.K. to use standard K-Eps model in my case? In the chamber, fluid velocity is not high. And reynolds number is small.
Regards, akr
Madhukar May 22, 2007 07:49
If the Reynold's number is very less ....you try with RNG K-Eps., model.
regards
