Periodic Conditions - 3Dblade
Old   May 22, 2007, 11:57
Default Periodic Conditions - 3Dblade
nick
Hi, I'm simulating a single 3D blade passage with periodic b.c. in the middle of the passage. I'm using the Pressure Based Solver (the Density Based Solver gives me problems). In the Periodic Conditions Panel do the Upstream Bulk Temperature and the Flow Direction refer to the inlet? The Flow Direction at the inlet is not the same as the direction of the periodic sides downstream the blade. Thanks
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
rotational periodic boundary conditions in ICEM user0314 ANSYS Meshing & Geometry 1 June 21, 2011 01:57
Activate Periodic Conditions IvanCFD FLUENT 3 May 13, 2010 07:02
3D non-conformal periodic boundary conditions Simon Riverin FLUENT 4 February 23, 2007 01:35
periodic boundary conditions Satish Perivilli FLUENT 0 January 28, 2005 11:54
