How to set interfacial roughness
Old   May 22, 2007, 07:35
Default How to set interfacial roughness
K. Baker
Hi all: I have stratified (air-water) flow within a pipe , the water flow in the button of pipe and air in the top and I am use the VOF model. I have the roughness value at interface between the phases from experiments and I did not know how to set it? Is there anybody can assist me with it?
Thanks in advance Saleem
Old   June 6, 2007, 23:42
Default Re: How to set interfacial roughness
mohsen
in boundary conditins menu, select and set the conditions for the wall for which you want to set the roughness, then select the momentum panel and set the value for the roughness.
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problems with installation of OpenFoam sheyer OpenFOAM Installation 8 July 28, 2008 03:45
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 05:45
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 04:16
