Home > Forums > FLUENT
turbulent viscosity
Old   May 22, 2007, 16:22
Default turbulent viscosity
nick
hi,
what if the turbulent viscosity warning message persists until convergence but it's limited to few cells? is the solution still valid? would you suggest to adapt the grid cells where the turbulent viscosity is high? Thanks
Old   May 25, 2007, 09:28
Default Re: turbulent viscosity
Brian Tang
I would say that it's a problem, even if limited to a few cells. The warning only appears when the turbulent viscosity hits unrealistic levels, so even cells that do not trigger the warning are likely to have overpredicted turbulent viscosity.
When you say "until convergence", is this from FLUENT's convergence criteria? If so, turn those off and continue to run the simulation until the residual history is flat and low for all variables. You will probably find if you examine the residual history, your turbulence residuals are still dropping and will be for some time yet (i.e., your solution is not actually converged yet).
Thread Tools
Trackbacks are On
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
