-   -   help me power failure!!! (http://www.cfd-online.com/Forums/fluent/44795-help-me-power-failure.html)
haiduc May 24, 2007 02:40
hi everybody, I have a problem. During calculating the power was interrupteb by tempest therefore my computer has been restarted automatically. I want to know that is it able to start the calculation at the moment interrupted by tempest. If I start from the very first it will take about 3 days.
Can somebody help me to solve this problem.
sam May 24, 2007 02:55
Re: help me power failure!!!
use autosave feature of fluent.
haiduc May 24, 2007 03:30
Thank you very much for your advice i will set it by the next calculation , but using the autosave panel is only useful to start the calculation from the very first. I do not want to start from the very first because it will take a lot of time. I would like to start at the moment interrupted. It is a very important thing for me.
Madhukar May 24, 2007 07:11
I don't think u can start the calculation from the point where it was stopped...with out enabling the AUTO SaVE command at the beginning of the simulation. I am affraid you should start the simulation again from the beginning. Don't forget this time to enable the AUTO SAVE command.
Regards
haiduc May 24, 2007 08:06
Thank, I also realized that does not work without AUTO SAVE option. I have just started the calculation from the beginning and also set the Auto save option :). On monday i will get the result of calculation :( Thank all of you for helping me!
