Home > Forums > FLUENT
What's the problem about this UDF?
Old   May 29, 2007, 21:56
Default What's the problem about this UDF?
williams
DEFINE_DPM_INJECTION_INIT(set_velocity,Inject) { Domain *domain; Thread *t; cell_t c; real xc[ND_ND]; Particle *pp;
loop(pp, Inject->p)//It said this line"structure reference not implemented"??
What's the problem? Any suggestion? Thanks
Old   May 30, 2007, 00:54
Default Re: What's the problem about this UDF?
Markus Alzon
I made a loop like this:
loop(p, I->p_init)
then you din' use curly brackets (or you did, and did not post them).
In this loop i set some values, like this: P_VEL(p)[0] = 0.0;
Hope, it helps you.
Good luck!
MA
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
