Home > Forums > FLUENT
properties of fluids
Old   May 30, 2007, 10:44
Default properties of fluids
rosol
I am working on microchannel heat exchanger which consist of two channels and seperating wall .When I use same fluid in both channels and want to specifying the properties of one fluid the other fluid will take the same properties of first fluid.My question is how can I specify diffrent properties for same fluids flowing in two channels . looking for answer
Thanks alot
Old   May 30, 2007, 10:49
Default Re: properties of fluids
Madhukar
Hi
I think, U have to define the two channels as seperate zones. For example zone1(for channel 1) and zone2(for channel 2. U have to do this while generating ur mesh. Then u can define different properties for the same fluid flowing in different channels.
regards
Old   May 30, 2007, 11:05
rosol
Thank you , But how to specify the different zones in gambit
Old   May 30, 2007, 11:13
Madhukar
Hi
In Gambit u can find a menu called Zones(on the top, right hand side of the Gambit window under Operation menu). here u can specify the zone type for a volume or a face or a group of volumes and / or faces.
Regards,
Madhukar
Old   May 30, 2007, 11:17
rosol
But I specified the zones in this way since I specify fluid to channel 1(volume 1) and solid to the wall (volume2) and fluid to channel 3 (volume 3) but when readuing this case in fluent I can't to specify difrrent properties to the same fluid in diffrent channels since when I change the properties of one fluid then the properties of second fluid automatically changed
Old   May 30, 2007, 11:33
Madhukar
hi again,
try this: in Fluent go to materials panel then for the first volume give a name(for ex: fluid_1) then define the properties of that fluid(like density, viscosity etc) with desired values. then press "change/create" botton. For the second volume give a name(fluid_2) then follow the same procedure as above.
Regards,
Madhukar
Old   May 30, 2007, 11:46
rosol
Thank you very much for your help But I also do that and also the properties of other fluid is changed automatically can you send me your email to be easy to contact you my email is rosolm2000@yahoo.com
Old   May 31, 2007, 08:56
Prasad Dudhgaonkar
As I understand from the discussion, in this heat exchanger problem, I feel you should specify the properties (e.g. viscosity, Cp, conductivity etc...) as the function of temperature. You need to relevant corelations if you want to use corelations other than what Fluent provides. This way you can work with the same material.
Hope this at least partially solves your problem.
Thread Tools
Trackbacks are On
Require the fluid properties of the following fluids at different temperatures rohitjvbibin Main CFD Forum 0 October 21, 2010 05:56
Require the fluid properties of the following fluids at different temperatures rohitjvbibin FLUENT 0 October 21, 2010 05:53
Turbulent flow of two incompressible fluids with the same physical properties ArneBab OpenFOAM Running, Solving & CFD 3 January 5, 2010 06:48
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Thermodynamic Properties of fluids at high temp hagupta CFX 3 March 15, 2006 13:55
