May 30, 2007, 11:09 |
how to fix the pressure on a surface
Hi!
I'm a student and I try to solve a problem of a swimming pool river. I would like to know how to fix the pressure to 1e+5 Pa on a surface (boundary) of my model. Thank you for your help that will be usefull for my placement. |
June 1, 2007, 10:36 |
Re: how to fix the pressure on a surface
Hi marion, you can choose pressure_outlet as boundary condition and put the value you want!
June 2, 2007, 01:43 |
Donia this only fix the pressure at outlet so that I suggets marion also must use the pressure inlet at the inlet in addition with the pressure outlet then he can set the pressure he want for his inlet that's my opnion for this problem?
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
