June 1, 2007, 08:45 |
skewness
hi everyone, could you tell me how to verify skewness in Gambit!
June 1, 2007, 14:05 |
Re: skewness
hi donia, click on Examine Mesh (bottom-right button), Display Type: Range, select all element types, Quality Type: EquiSize Skew, Update. The green bar will give you info on the skewness distribution. You can also click on the Mesh Command Button (top-right button), right click on the "i" in the volume panel (or Face panel for 2D) and select "check", select the volumes (or faces) you want to check, Apply. Enlarge the Transcript window and see the info. See the manual for good mesh quality requirements.
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
TGrid High Skewness | khimkhim | ANSYS Meshing & Geometry | 1 | February 17, 2010 23:36 |
problem with skewness | jjchristophe | FLUENT | 1 | January 14, 2010 21:22 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
Skewness | Taskin | FLUENT | 5 | April 6, 2005 15:21 |
