Non dimensional calculations
Old   June 1, 2007, 02:13
Default Non dimensional calculations
rosol
Is there are a possibility to work in dimensionless form in fluent ,If yes how
thanks alot
Old   June 1, 2007, 10:25
Default Re: Non dimensional calculations
Donia
hi, you can work in dimensionless form!calculate your values and just work with that whatever the units are!!
Old   June 1, 2007, 13:13
jasond
Yes. Sort of. In the past, I created a new material (Define->Materials...) with unity viscosity and density equal to the desired Reynolds number. Then, generate the grid nondimensionally and that is it.
It gets harder if there is heat transfer involved, but I guess you could do the same thing.
Old   June 1, 2007, 13:53
rosol
Thank you for answer
Please can you explain the manner in detailed How can I defin the governing equations in nondimensional form and how can I define the values of properties
Thanks
Old   June 1, 2007, 19:41
jasond
I don't think I understand you - what do you mean? Actually, I should also check that I remember correctly what I did. I'll do that tomorrow, but you should keep in mind that this is not really a standard use of Fluent, and it shouldn't make any difference anyway.
Two or Three Dimensional for a coil Asghari_M ANSYS Meshing & Geometry 0 June 7, 2011 05:28
Bulk temperature in three dimensional calculations Halim Main CFD Forum 0 June 29, 2008 19:18
importing geometry from three dimensional subject George Kagadis FLUENT 0 September 30, 2004 01:35
Non Dimensional Parameters J.J Main CFD Forum 1 June 28, 2000 20:12
Implicit transient calculations using Fluent5 G. Berntsen Main CFD Forum 4 November 10, 1999 15:32
