UDF Format 8th Order Poly Fit
Old   June 8, 2007, 12:36
Default UDF Format 8th Order Poly Fit
Jason
I am writting a UDF to model the Womersly solution for a tube. I have fit 8th order polynomials to the Bessel functions. When I use my code in MatLab I obtain the correct answer. When I format it for the UDF applied at the inlet velocity b.c. I beleif the problem to be associated with my 8th order polynomial fit. After ploting the velocity points from both the Matlab version and from Fluent, they match very closely from r/R = 0 to r/R = .5 but after that are radicaly different. Is there anyway of dealing with these "higher frequencies"? I interpert it with no error messages. I can send you the UDF and the MatLab m.file if anyone is interested in helping. Thanks, Jason
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
How to calculate second order derivatives using udf? legendyxg Fluent UDF and Scheme Programming 0 October 6, 2009 22:05
UDF Format 8th Order Polynomial Jason FLUENT 2 June 24, 2007 13:21
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 10:19
UDF for second order moments in LES Jimmy FLUENT 0 September 6, 2002 11:16
