Problem with Non-Premixed model (coal burner)
Hello:
I´m modeling a coal burner with non-premixed model. I´ve got one fuel stream (coal) and two oxidizer stream with different compositions. I must apply two-mixture-fraction approach.(three stream with different composition).DPM iteraction every 25 continuous phase iteraction. I´ve a problem about this approach: Fluent update properties continuous phase every ten iterations. I plot some variables (temperature,O2,mass flow rate). When Fluent do this update properties, these variables increase or decrease its value too much (example: Tempearture changes from 2000 K to 500 K approximately, it changes from 500 to 2000 at the next update it happens every 10 iterations). The solution can´t converge because of these great changes of the fluid properties.I don´t understand this approach. Could somebody explain me two mixture fraction approach? How can i converge my case? My english is so bad.I´m sorry. Thanks |
| All times are GMT -4. The time now is 09:44. |
