connecting two fluent files.......?
Old   June 6, 2007, 11:56
Default connecting two fluent files.......?
madhuri
hi iam madhuri.i have geometry such a way that it has one volume rotating besides other one fixed.the rotating volume has 230 small tubes which are set into rotation.so i have done 2 gambit files one for rotating tubes and the other file for the other volume which is seemed to be the upstream for the rotating ones. i came to know that the results at outlet of first fluent can be inputted as inlet to another and i dont know how to do this.can any one let me know the step by step process of doin this.thanks in advance.
Old   June 7, 2007, 16:59
Default Re: connecting two fluent files.......?
Prasad Dudhgaonkar
After getting converged solution from case (zone), you can append your case file through Grid-Zone-Append Case File and start solving further.
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Videos in FLUENT - HMF files xavi FLUENT 9 November 17, 2009 04:39
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Converting .geo files into Fluent newuser FLUENT 0 September 10, 2001 13:38
