Home > Forums > FLUENT
Two-phase flow
Old   June 7, 2007, 09:02
Default Two-phase flow
mvee
Hi, I have two questions:
1. Is that possible with fluent to carry out simulation for two-phase flow in annular, slug, plug, wispy annular and mist regime? Is there any tutorial for the same?
2. I want to know that fully developed flow can be defined at the inlet only through UDF? or is there any other way to define fully developed flow? Because if i start the simulation in normal way then it will require large fully developed length. So, how can i reduce fully developed length in two-phase flow?
thanking you and have a nice day
Old   June 7, 2007, 09:42
Default Re: Two-phase flow
AAS
2. You can run a simulation on a sufficiently long representative geometry until you get fully developed flow and write the velocity profile (write BC). You can use that saved profile for your real geometry inlet(read BC).
Old   June 8, 2007, 00:04
mvee
I thought that this is posible for single phase flow or can it be applied to two-phase also? Why i am asking this because due to presence of another phase the velocity profile in the pipe gets changed. So writing the fully developed velocity profile and applying to real geometry can solve my problem?, AAS
Thanks a lot AAS
Old   June 8, 2007, 16:29
A A S
I have used this in the discrete phase model. I write the profile for fully developed flow and then read profile in my actual case for the inlet. This has helped stabilize a very sensitive reacting flow solution. I am not certain it applies the same for multi-phase with large volume fraction of second phase.
good luck AAS
Old   June 9, 2007, 00:57
mvee
Thanks for your reply. If i find the solution then definately will come to you. You please also find the answer then reply me
thanks once again AAS
Old   June 19, 2007, 08:18
selim
We can not solve condensation of R134a in a pipe with Fluent, CFX, CF-Design programs. I could not find any article in citation index about condensation (two phase flow problem) solution with any program. Our university is ready to pay its fee for solution...
Old   June 25, 2007, 06:39
mehdi atapour
Hello I want to model two phase flow in a laval nazzl. Please help me. Yours truly mehdi atapour
Thread Tools
Trackbacks are On
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 08:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
