Home > Forums > FLUENT
access violation on periodic conditions
Old   June 7, 2007, 12:35
Default access violation on periodic conditions
John Deas
I would like to write flow fields values (for an unsteady case) using an "execute at end" user defined function so I can have a sequence and look at the evolution. I really would like to implement this with an UDF.
If the boundary over which I loop to get the C_U values is a velocity inlet, it works and I get the value I put in the boundary condition panel. But, if I want to loop over a periodic boundary condition, with the same code, I get an ACCESS VIOLATION
Here is the small code I wrote to test the loop. thread_id=5 correspond to the boundary condition.
#include "udf.h"
DEFINE_EXECUTE_AT_END(execute_at_end) { Thread *th = NULL; Domain *domain = Get_Domain(1); int thread_id = 5; cell_t c; float speed = 0;
th = Lookup_Thread(domain,thread_id) ; begin_c_loop(c,th)
{ speed = C_U(c,th); printf("%f\n",speed); } end_c_loop(c,th)
However, I can get other value in the periodic case (for example, the centroid position): only retrieving the speed components is not working.
Thanks,
John
Thread Tools
Trackbacks are On
HELP,how to define the periodic boudary conditions using the icem mesh? dada1204 FLUENT 2 May 1, 2012 17:06
Setting turbulent plane poiseuille model to periodic boundary conditions. QBeast FLUENT 0 July 17, 2011 10:08
rotational periodic boundary conditions in ICEM user0314 ANSYS Meshing & Geometry 1 June 21, 2011 01:57
periodic conditions, temperature not converging Husain CFX 3 April 29, 2007 19:21
Urgent: periodic boundary conditions ck1973 FLUENT 3 July 5, 2006 11:32
