-   -   New Material (http://www.cfd-online.com/Forums/fluent/44974-new-material.html)
M.E. June 8, 2007 13:59
New Material
Hi, I'm trying to create a new material to inject in DPM. everytime I create this new material, and enter all the properties, I'm unable to save it, it'll give me an error message..
Any idea why?
Can anybody please give me a brief procedure on how to do it?
your help is greatly appreciated! thx
Shanti June 8, 2007 14:24
Re: New Material
Could you tell what the error is?
M.E. June 8, 2007 15:07
Re: New Material
1- Define > Materials 2- User-Defined Database 3- I create a new file 4- New 5- I enter the name, type (droplet-particle), and insert properties 6- when I click apply, i get the following error:
Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: ()
Error: list-remove: null list Error Object: #f
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f
zhaoh June 10, 2007 00:05
Re: New Material
1- Define > Materials 2- Fluent Database...3- Fluent Fluid Materials...cope...4 you can change the properties of the materials.Change/Cope...5 Define->Injections...-> select the material of particle which you have dealed with.
nick June 11, 2007 09:04
Re: New Material
Is it necessary to create the new material in the User-Defined Database? To create a mixture, for example, usually I add the species I need from the Fluid panel, then I select Mixture and, using the Edit button, I add the species I want to be in the mixture, then under Name in the main Material panel I rename it as I want so I can eventually modify mixture and/or species properties.
Xiana June 11, 2007 09:24
Re: New Material
I use to create first of all one injection with the default parameters (inert particle).Then I go to the material panel, I choose in material type "inert", I write there the desired parameters (name, density...) and save it. normally I overwrite anthracite (the default inert material). But that only works when you are using inert particles!
Xiana
M.E. June 11, 2007 10:06
Re: New Material
Thank you all for your replies, I tried it and it helps...
