Density is a function of location
Old   June 11, 2007, 14:17
Default Density is a function of location
magda
Hi all,
I have a question about defining density. Is it possible to define the fluid density as a function of location?? say it depends on x, y coordinates only.
thanks, magda
Old   June 11, 2007, 15:02
Default Re: Density is a function of location
charafedddine
hi, yes it depends on x, y and the time
Old   June 11, 2007, 15:20
magda
hmm...ok...if it's a steady state case so i don't have to consider it depends on time.
how can i define that?? I tried to write a udf and compile it, but it didn't work. I used a DEFINE_PROPERTY function. can you give me more hints? thanks
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
UDF for density as a function of something not necessarily temperature! rmousavibt FLUENT 0 May 12, 2009 10:12
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 02:41
User defined function for density gradient ben akih CFX 3 October 10, 2006 21:47
Warning 097- AB Siemens 6 November 15, 2004 04:41
