Display surface
Old   June 12, 2007, 10:36
Default Display surface
cotket
Hi all i am new to this forum, i am using Fluent to simulate a 3D model. The model consist of two tube in parallel. I want to display only a surface of one tube,i don't know how to display a cross-section of each tube. Can anyone help me to do this. Thanks
Old   June 12, 2007, 13:07
Default Re: Display surface
amir
hi you mean that u dont want see both of them in same window?
Old   June 13, 2007, 02:51
cotket
Thanks for your response, i want to see tube separately. Because i need to calculate wall shear stress at each cross section. If both of them display in the same window, the value becomes average. Thanks again
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
free surface display carno Siemens 4 October 7, 2005 01:03
free surface display novice Siemens 5 August 4, 2004 01:07
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
