June 8, 2007, 22:15 |
Dynamic mesh error
I used dynamic mesh nad the below error occured: Warning: negative cell volume detected! Error: Update dynamic mesh failed. Negative cell volume detected. could anyone help me what to do with this? Sham. |
June 10, 2007, 14:35 |
Re: Dynamic mesh error
hi i think this message is about ur mesh. i think u should use another type of cells depend ur Dynanic mesh setting. best
June 13, 2007, 04:23 |
Hi
When you enter the time step before computing, make sure it is such that the movement of the object in the time step is less than the max size of the cell. Try reducing the time step and checking. Sid |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
