June 13, 2007, 20:36 |
Shear stress on liquid surface
Hi everyone.
I want to know the shear stress between the liquid (water) surface and air. Is this shear stress different from that between solid wall and air? Thanks, akr |
June 14, 2007, 06:11 |
Re: Shear stress on liquid surface
It is usually differ becuase at gas-liquid interface the relative velocity (vg-vw) was not the same as the gas velocity at the wall hence the shear stress not the same.
K. Baker |
June 15, 2007, 00:39 |
Hi, Baker. Thank you for your reply.
Now I want to model gas flow in the chamber. This is my experimental apparatus. Acutually, in the apparatus, there is the liquid layer, approximately 30 mm in depth. So when I model the gas flow in this apparatus, I create a grid without the liquid layer. In the model, I set the boundary condition of the bottom face (this is acutually liquid surface) wall boundary and no-slip condition. So now I want to set a specified shear between interfaces of gas and liquid. Do you know what to do for? Is it O.K. to set the no-slip condition? Thanks, akr |
June 15, 2007, 01:18 |
I think if you want to set interfacial shear you need to consider the wall as a moving wall and set its velocity equal to the highest velocity of liquid (Ui) I am not try this method in my calculation yet but I have a paper consider the interface as this so try it and see if it useful for you?
REGARDS Khalid Baker |
Shear rate and Shear stress | kakarot9999 | FLUENT | 0 | September 8, 2011 08:28 |
Fluid wall shear stress | Sinead Kelly (Kelly) | OpenFOAM Running, Solving & CFD | 2 | March 30, 2011 06:41 |
Wall Shear stress in 3D | nikosb | Main CFD Forum | 1 | April 15, 2010 03:52 |
Wall shear stress distributions | en51nm | STAR-CD | 2 | January 28, 2010 04:42 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
