Home > Forums > FLUENT
Plot
Old   June 14, 2007, 13:45
Default Plot
Pelli
I'm modelling water flow in a three dimensional fracture. I need to create a file.dat which shows the velocity value in each cell associated with the xyz position in space of the center of the cell. Something like this X Y Z velocity 1 1 1 0.2 2 1 1 0.3 3 1 1 0.15 etc. etc.
Is it possible? Can you help me? Thanks
Old   June 14, 2007, 18:51
Default Re: Plot
Tomasz Bednarz
Dear Pelli, Just create post-processing zone and make it type as interior. In this way you can create artificial cuts through channel and get values of velocities, temperatures by iterating all cells values... However if you like to have those values for whole fluid zone, simply do iteration over or cells in specific zone using UDF, look at UDF manual - there you have many examples
Old   June 15, 2007, 00:17
Default Re: Plot
krishna@cusptechnologies.com
There are many options available in fluent to access the final results. You can go with iso-surface/ grid or create line and can plot the properties over the line.
Thread Tools
Trackbacks are On
Plot on a curve Monica FLUENT 1 July 11, 2012 00:24
A girl fail to plot velocity profile when mesh changes + Wall function asherah STAR-CCM+ 0 February 19, 2010 18:45
Transfer low-res graphic file plot to excel plot quarkz Main CFD Forum 3 April 9, 2009 13:54
graph plot anindya Main CFD Forum 2 September 17, 2003 12:00
why can't I plot Y+ value? Jiaying Xu CD-adapco 2 August 18, 2001 10:56
