June 5, 2007, 11:48 |
XY Plot with Time
HI, I want to plot a graph for swirl velocity v/s flow time for a point with different mesh sizes (i.e different cases). What I am doing is monitering surface with flow time on X axis. But it only give the convergance history for the swirl velocity at the point.
I acutally want to plot how swirl velocity changes on the point with time.(x-axis= time, y-axis= swirl velocity). Thanks Ketan |
June 15, 2007, 09:16 |
Re: XY Plot with Time
I would like to know it too thanks
June 15, 2007, 11:07 |
define apoint
use solve monitor surface monitor and define the monitor to plot/print/write the velocity with flow time. |
June 15, 2007, 11:34 |
Thanks. I have one more query. I have a point in the fluid domain on which I am getting value of swirl velocity, which is there due to problem set up, whose value is around 1.49cm/s. But now I want to initialize this swirl velocity at that point to be 0.165775 cm/sec. How do I do it.
I tried to initialize in the "initialize panel" but what actually it does is that it adds 0.165775 to the swirl velocity of 1.49 (so it becomes 1.65577 cm/sec ) Also I tried to do patching, it does take this value but then after certain iterations the value of swirl velocity starts increasing(which actually should decrease) when I see in surface monitor window for that point. |
June 15, 2007, 13:06 |
sorry, I won't be able to help you much with that.
[OpenFOAM] plot temperature vs time in paraview - chtMultiRegionFoam | phsieh2005 | ParaView | 2 | March 16, 2014 06:50 |
directMapped problem | panda60 | OpenFOAM Bugs | 4 | July 8, 2010 10:23 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
PLOT TIME vs PRESSURE | Parshant Dhand | FLUENT | 0 | January 17, 2003 15:31 |
