Compilation error with C++ header file
Old   June 15, 2007, 11:54
Default Compilation error with C++ header file
Jack Martinez
Hello again
When I tried to compile a UDF with a < iostream.h > as one of the header file using interpreted method in Fluent, it gave error:
Error: iostream: line 14: parse error.
and when I tried to compile it using shared library, it built a shared library with this error message:
"C:\Programme\Microsoft Visual Studio\VC98\Include\eh.h(32) : fatal error C1189: #Fehler : "eh.h is only for C++!"
and when I tried to link this build library it gave this error message:
Opening library "libudf"... "Error: open_udf_library: The system cannot find the indicated file."
Could someone please explain what preliminary steps required to be followed to link/use C++ functions and programs with UDF in Fluent.
Regards
Jack Martinez.
Old   June 15, 2007, 19:33
Default Re: Compilation error with C++ header file
Tomasz Bednarz
Jack,
As for UDF, I recommend you to use plain C, instead of C++. Therefore use use stdio.h functions for reading, writing, parsing etc... As for iostream.h, new visual studio have some changes in default libraries and if i remember well you should do #include <iostream> instead of #include <iostream.h>.
Another thing is: DO NOT USE interpreted version, but USE compiled version method in Fluent if you want to use external c/c++ features... internal compiler is very limited, remember about it...
kindest regards, Tomasz
Old   June 16, 2007, 08:40
Default compatibility of C++ with UDF (FLUENT )!
Jack Martinez
Hello Tomasz,
Many thanks for ur reply..
I have to use C++ along with my UDF in Fluent as I said before I have to postprocess fluent result for radiation modeling and further..
I even tried to implement it using compilation method but it didn't work out...
Does modifyiing the env variables or including some header file in the path can lead to solution...
I am currently working in Windows but finaly I have to implement it in Linux ...
Regards Jack
Old   June 16, 2007, 09:27
Default Re: compatibility of C++ with UDF (FLUENT )!
Tomasz Bednarz
Jack,
Under Linux all is simpler and straightforward -> GNU C/C++ is included by deafult into the system and you really don't need to do anything when using compiled version of UDF,
Send your UDF code to my email - I'll check it out if you have not enough experience in C/C++, maybe i'll be able to give you good clues on that,
env variables they give only paths for compiler...
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
