problems for unsteady calculation
Old   June 20, 2007, 03:08
Default problems for unsteady calculation
olivier
Hi everybody, I want to do an unsteady calculation for a flow over a flate plate in horizontal duct (like a forward-facing and backward-facing step).
-I calculate a steady-state solution before.Is it the best solution ?
-I tried with an adaptive time stepping method with the default values. But which is the criteron to determine the best time step size for a fixed time stepping method.
-Why my unstedy model give me a steady solution when I visualize my animation? My model is maybe steady or there is a problem in the calculation ?
Thanks a lot !!!
Old   June 20, 2007, 09:13
Default Re: problems for unsteady calculation
Laure
I think that if you are that your problem is unsteady, you don't need to calculate a steady-state solution before. You can directly calculate an unsatedy-state solution.
For the criterion to determine the best time step size, it is the CFL number. You initialize this criterion in solve -> controls -> solution.
Laure
Old   June 20, 2007, 09:17
olivier
Thanks Laure (merci d'avoir répondu et bon courage pour la suite)
Old   June 21, 2007, 02:13
James
You didn't say whether you were using RANS or LES. With RANS, you might seem to be having a steady state solution at the onset. You'll have to allow it to run for a considerable period of time before you get rid of the steady state behaviour.
Hope this helps.
James
Old   June 21, 2007, 02:28
olivier
Hi James, I used a k-e model. I don't know which model is the most adapted for this kind of calculation. I'll try a RANS model. Maybe my unsteady calculation didn't work over a rather long periode of time to became unsteady? Thanks James.
Old   June 21, 2007, 02:45
James
I suggest you do some computation of the calculation time it will have to take you for your information to travel through your computational domain...with this, you will then allow your RANS simulation to run for this period of time after which you see some unsteady effects. You need to know the length of the domain and the average axial velocity and the ratio of the two will give you an idea of the computational time needed. If it doesn't work, i suggest you switch your RASN steady state solution to LES...i mean from your RANS steady state solution, you will switch over to LES and see how it will be behave...maybe it will be able to capture all the unsteady effects associated with your flow.
Hope it helps.
James
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
[FloWorks] Request advice for an airfoil calculation problem Bogey Jammer Main CFD Forum 0 September 29, 2009 17:06
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
Some problems with Star CD Micha Siemens 0 August 6, 2003 13:55
Temperature calculation problems Julie Polyakh Siemens 1 January 15, 2002 20:50
