outflow boundary condition for multiphase flow
Old   June 21, 2007, 04:42
Default outflow boundary condition for multiphase flow
deepak
is it ok to use outflow boundary condition for multiphase flow, with air coming thru nozzle? outflow can't be used when density is varying in unstaedy calculations..now if pressure is changing inside the capillary, then density can vary. Under this case, wat should be outlet boundary condition?
Old   June 21, 2007, 08:23
Default Re: outflow boundary condition for multiphase flow
Neil
use a pressure outlet. If M<0.3 you can assume the flow is incompressible and use the pressure based solver, if not use the density based solver.
Boundary condition for exhaut flow with imposed mass flow stephane FLUENT 1 November 24, 2011 02:04
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 14:19
mass flow inlet boundary condition vivian FLUENT 5 April 21, 2006 06:23
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Outflow boundary condition in FLUENT Sri FLUENT 5 December 5, 2003 04:42
