June 21, 2007, 11:59 |
Who can answer me /pressure question
Hi I need to know how can fluent predict the static pressure at inlet depending on the velocity inlet boundary for a pipe flow? Is there anyone have any comments? knowing that i was use two phase flwo
Pam |
June 21, 2007, 18:56 |
Re: Who can answer me /pressure question
Extrapolated from interior based on reconstruction gradients. These reconstruction gradients are calculated using Venkatakrishnan's limiter.
June 22, 2007, 02:14 |
Hello thank you to the answer can you tell me what you mean by Venkatakrishnan's limiter with more details?
Thank you pam |
June 22, 2007, 09:40 |
Dear Pam
Fluent calculate the pressure by solving the momentum eqquation (N.S.E) which contain the pr.gradient which is first drivative so it need one boundary condition most be specified in inlet or in outlet in your case you must choos the outlet B.C is pr. outlet so the fluent will solve the N.S.E and from it calculate the distribution of pr. I hhope this answer help you and if not please don't hestite to contact me |
June 22, 2007, 10:14 |
Thanks rosol to the answer. Actually FLUENT give me very less values of pressure gradient when I compared it with a paper in the same problem as mine knowing that I used the same BC that mentioned in that paper but the results still less can you tell me why?
pam |
June 23, 2007, 00:51 |
May be due to the properties of fluids used .or the operating pr. used in the paper diffrent with which used by you or may be the paper define the pr. in absolute while fluent sue the gauge pr.
Regards |
June 23, 2007, 02:10 |
No i made all the same as in the paper?
Pam |
June 23, 2007, 08:50 |
I think there are some thing wrog .since the results of fluent is correct if the B.C uesd are correct .Please check your case B.C , velocity inlet and other effective parameters .I hope you find the cause
Display Modes | |
To red lemon pls answer | K.Baker | FLUENT | 0 | August 2, 2007 10:41 |
question in need of an answer | cfd_student | Main CFD Forum | 2 | December 17, 2005 07:00 |
Convergence Question | James | FLUENT | 2 | October 29, 2005 15:59 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 05:37 |
A simple question (Where is the answer? Not yet!!) | Mecobio | Main CFD Forum | 1 | February 12, 2004 08:28 |
